This is an awesome forum! Glad I found it.
On to the motor: The performance has deteriorated over the years (as you would expect). It's on 14' Glastron runabout. We used to waterski behind it in the 80's (it's been in the family for a while) but I haven't used it in about 4 years now as it was having a hard time pulling a 3 person tube. Back in the 80's it would run on plane at an indicated 26mph and sound pretty strong. I took it home from the cottage thinking I was just going to sell it. I cleaned the carb, found an air leak in the plug at the top of carb, sealed it and now it idles better than it ever did! Go figure...now I'm wondering if I should fix up the boat and keep it. I still have to test it on the lake. The lower end needs new seals, that's for sure. What should the compression be? Where would I "plug in" to vacuum test the block to ensure the crank seals are good? Is it big $ to rebuild the top end? Any thoughts/comments would be appreciated.
