Fogging oil connector 3-cyl 70HP
imported_Jimbo
Hello,
What kind of adapter do you guys use to connect the spray-can with fogging oil to the valve on the SB side of a -97 Johnson 70 carb 2-stroke? As far as I can see it is the same type of connector as a tyre-valve?
Also, any good tips on how to empty the carbs in the simplest way? I really miss the small hose-connector I have on my motorcycles...
BR Jimbo
mckee1787
Re: Fogging oil connector 3-cyl 70HP
You should be able to purchase the same fogging can with a hose and with a schrader valve fitting.
