  #1
Old November 1st, 2009, 06:31 PM
LilAnxious LilAnxious is offline
Default Islander Test Run.. Couple Questions
Well the first water test run on the 72 Islander went well today. Boat didnt leak a bit. Not a bit of water taken on. Motor and drive both ran strong. Couple questions though.
1) Balance. Very little static weight load in the boat. Seats & old fuel tanks removed. The whole thing tilted when one of us moved. I am assuming once I add seats, hardware, fishing gear, and fifty gallons or so of fuel it will balance a lot better. Any input?
2) Thermostat. Water temp probably about fifty degrees. The thermostat never opened. Gauge warmed up to about the mid of the green and never past, but not sure how accurate this is. Gonna change it anyways this winter. Never got it to open either running on ears. Wondered if this was normal on ears or in cool water.
3) Little smoke out the oil breather at higher RPM's (4000). Nothing massive just a bit. Boat has been layed up for 7 years. Fresh oil and filter. Didnt know if this means I need to dig a little deeper in this motor, or maybe old build up.
I'll also ask the last two questions in the engine section. Any thoughts or advice appreciated.
  #2
Old November 1st, 2009, 08:44 PM
Huron Angler's Avatar
Huron Angler Huron Angler is offline
Send a message via MSN to Huron Angler
Default Re: Islander Test Run.. Couple Questions
Lilanxious...glad to hear that the motor runs and that the hull doesn't leak. Two huge victories right there alone
As far as the hull rocking when you move, those deep-V hulls will do that even when it seems like the wide beam should prevent it. I've been on 24' fiberglass rigs that have 100+ gallon fuel tanks and they will still list a bit just from a 200lbs guy moving port to starboard on deck. Nothing will prevent that altogether but added weight will help.
Do you have a belly fuel tank that hasn't been filled yet? 50 gallons weighs quite a bit so that will help if it's situated low in the hull.
Possibly adding trim tabs and keeping them flat would add a bit of stability maybe, and keeping any weight as low as possible in the boat.
Post some video of her planing out if ya can...we'd love to see her in action
__________________
1979 16' Starcraft SuperSport w/ '70 80hp Mercury
1960s 12' AeroCraft w/ '55 5.5hp Johnson
"The gods do not deduct from man's allotted span the hours spent in fishing"
  #3
Old November 1st, 2009, 10:54 PM
North Beach's Avatar
North Beach North Beach is offline
Send a message via MSN to North Beach
LA, that tilting thing sounds about right, although mine doesn't seem to lean but just a little to the fat captian side
What engine? 120 or 140?
And I just gotta say again your boat looks good....seriously!
  #4
Old November 2nd, 2009, 01:45 AM
Kainon's Avatar
Kainon Kainon is offline
1. Balance.. Yea.. thats what I get too..
2. Thermostat: Well if the water is cold (50) yea.. it will run cold especially if the cooling system, impeller, manifolds, circulation pump is in good order.. yea it should stay cool.. depending on the prop and how much weight in the boat will affect a little due to more strain on the engine too.. and how high and long you take the RPMS.. I see this a lot on ears as the engine isn't making much heat.
3 Smoke at high RPMs.. well could be stuck rings.. there's a few things you can do (additives) etc.. to help that.. also could be valve guide seals, valve guides.. or just 1 or 2 worn cylinders.. 1 of the first things I feel you should've done was a compression test ( as you didn't mention it ) this well give you an idea on the condition of the engine.
hope this helps. - brian
__________________
1974 Starcraft Islander 21' Mark IV
Mercruiser 165hp Inline 6
GM 250ci - from a '74 Nova
Bored .030, Balanced, w/Hardened Exh Valves
Aluminum Plate Dash
Pics
Story
  #5
Old November 5th, 2009, 01:37 AM
elkhunter338 elkhunter338 is offline
Your thermostat should work no matter how cold the water. Replace.
Run the engine some see if she burns oil, check compression, check oil pressure with a manual gauge when the engine is at operating temp to see if it is good.
Caution do not use any brass pipe or fittings to install the manual oil pressure gauge. Brass will fracture quickly due to vibration.
If all checks out good I would run the engine.
  #6
Old November 5th, 2009, 02:41 AM
Pugetsound Pugetsound is offline
Elkhunter is right, about the Heating, The thermostat makes sure it runs at the right temp reguardless of the water temp. Sounds like the thermostat is faulty or there is not one installed. Engine is also used for heating the interior. if so plumbed. Very important to get it right as a lot of problems result if to cold or to hot. It should be about a 140 thermostat if that has a in line 6 or a in line 4cy engine. Oh and use a Marine thermo. there stainless steel and reccommended.
  #7
Old November 5th, 2009, 10:49 AM
Kainon's Avatar
Temp Gauges usually start @ 100F so if it moved off the bottom, and moved say 1/8"-1/4" that would be about right, you can put a gauge on that has numbers to help. the thermostat could be stuck a little open, given the age it's not a bad idea to change it.
See the line between 100 and 175.. that's 140, typical temp rating for raw water cooled I/O's.
And having a gauge like this classic mercruiser, the green section is huge, from 140F-220F I beleive.
How do you know the thermostat didn't open? having you hand on the hose from the therm housing to the riser.. it should be cool as cold water comes in, fills the block ( get's circulated ) only when it's hot does it come out and go into the manifold, as long as the engine wasn't overheating, that means the water it's taking in is cooling the engine, the thermostat not opening means the waters not getting hot enough, your not generating enough heat, that's a good thing !!
Still, best to change the thermostat, remove and clean the sender threads, electrical contacts and any rust inside the housing.
__________________
Aluminum Plate Dash
Pics
Story
  #8
Old November 5th, 2009, 01:46 PM
efgolden efgolden is offline
Place your thermostat in a sauce pan on your kitchen stove and observe while using a candy thermometer ......you will have your answer within 5 minutes.
  #9
Old November 5th, 2009, 09:10 PM
Rickairmedic's Avatar
Rickairmedic Rickairmedic is offline
Send a message via MSN to Rickairmedic
Testing the stat can actually be done without the candy thermometer . The way my dad taught me was pretty simple bring the saucepan to a boil and drop in the stat if it opens its good if it doesnt its bad . This test was always performed on new replacement thermostats ( you would be surprised how many dont open new right out of the box .)
Rick
__________________
Current Resto Project
1970 Starcraft Jupiter V 16'
http://forums.iboats.com/showthread.php?t=322858
Starcraft owners be sure to check out the 2010 get together thread .
http://forums.iboats.com/showthread.php?t=337378
  #10
Old November 5th, 2009, 10:20 PM
AmigoAzul's Avatar
AmigoAzul AmigoAzul is offline
I had a 21 ft Trophy with trim tabs. If I didn't trim the balance would be off with 2 on one side. Nothing to worry about. Tell the third guy to get in the middle.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Couple questions on a 115 MotorheadI000I Johnson & Evinrude Outboards 5 April 30th, 2009 08:25 PM
couple of questions. brunolund Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 May 21st, 2008 10:35 AM
Just a couple of questions... Txfroggy Boat Restoration and Building 5 May 19th, 2008 03:31 PM
A couple of questions - Thermostat and Fogging Questions valkyr Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 November 5th, 2007 11:40 AM
WOT during compression test? and couple other questions so Johnson & Evinrude Outboards 6 March 19th, 2007 08:23 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
