rcdriver11
- Sep 9, 2009
- 11
Someone please help I bought the boat a couple years ago I changed plugs wires cap rotor points and coil. Seems like I have to adjust my points every other time I go out. And have had to replace them about 6 times since.
A couple times I couldn't figure out why it wouldn't start checked for spark and couldn't find any, from plug wires or coil. After a while I got it to start and it ran great for a few trips. Then same thing. adjust or replace points and it runs great. Last week I went out and ran good but seemed to have slight miss only once in a while. Then went to go out yesterday, backed down the ramp, started the boat with no problem. Let it run at 1/4 throttle for a couple minutes to warm the engine as it is older and a little cold blooded.
When I pulled the throttle back to idle off the trailer the motor died. Then it would not start again. I looked for spark and couldn't find any. After an hour messing with it trying to adjust points, and find spark, I gave up.
This morning went out and tried it. It fired right up but I shut it off as I had no water going to it. Tried to crank it again and would not fire. Now I don't find spark. Any Ideas????
