Re: Yamaha C60 Bogging
Sounds like a fuel delivery problem. start back at tank pick-up/check valve/screen, fittings, primer bulb, quick disconnect on motor, fuel filter, fuel pump, then carbs. What kind of primer bulb do you have? are you sure carbs are really clean? drain carbs onto clean white rag to see what's in them. No air leak at quick disconnect? Good Luck!
