JGra
- Apr 24, 2009
- 222
OK, These forums help me to return a 69 Merc 200 back to the water. My next project is 25 hp Evinrude (serial number 2520R-E04783). than was given to me. I think its a 71 model. I checked and cleaned a few things just to make sure is was worth the effort. After sqirting a small amount of fuel into the carb it fired off for about 3 seconds. I am now iin the process of rebuilding the fuel pump and rebuilding the carb. I am also going to replace the impeller and all the fuel lines. Is there anything I should no about these motors. Also where does the water pee out of? Also I cant see how you can use the muffs on these. Looks like the foot has to be submerged in a barrel. Any help would be great. Thanks
