  #1
Old September 22nd, 2009, 07:22 PM
ajohnson035 ajohnson035 is offline
Unhappy 2000 50HP Evinrude EFI Check Engine Light 4 stroke
My check engine lights activates after running the motor about 10-15mins. New water pump installed and the thermostat is operating when tested. If I take the T-stat out the check engine light comes on in about 3mins. When its in 10-15mins running about 6,000 rpm. The head of the motor where the T-stat is located got hot to where I could only hold my finger there for about 2 secs w/o getting burned. However it never cut my power at all. I let it cool off a little and started it back up ran it back to dock at about 4,000 rpm no light activated. I took T-stat out and it stayed cool however the light still activated. I put the T-stat back in and the light activated again after about 10-15mins HUGH. The T-stat when tested was starting to open at about 130-140 degrees. What should I do next. It is a 4 stroke and the model # is E50PL4EE
  #2
Old September 22nd, 2009, 09:51 PM
Anchor Management 1 Anchor Management 1 is offline
Default Re: 2000 50HP Evinrude EFI Check Engine Light 4 stroke
Is there a water /fuel seperator on the engine? If there is water in it ,it will turn on the check eng.light.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2000 Evinrude 50HP EFI Check Engine Light ajohnson035 Johnson & Evinrude Outboards 2 September 21st, 2009 08:29 PM
2000 Evinrude 50Hp Electronic fuel injected the check engine lights comes on. ajohnson035 Johnson & Evinrude Outboards 0 September 19th, 2009 01:55 PM
2000 225hp check engine light thehermit Johnson & Evinrude Outboards 0 August 5th, 2009 09:20 PM
Check Engine light comese on 2000 / 200 Fichts CaptD Johnson & Evinrude Outboards 12 March 25th, 2008 09:52 PM
2000 200hp evinrude-check engine light mdegood Johnson & Evinrude Outboards 1 January 2nd, 2004 12:48 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
