Any experience with the injector cleaners online?
Idled fine, would not get on plane. Drained all old fuel, replaced fuel sending unit (top was corroded), added F/W separator using Yamaha filter (did not exist prior), cleaned fuel rail, and tried to blow off injectors and changed spark plugs, measured fuel rail pressures ....finally borrowed four injectors from a friends boat, and miracles do happen. The boat ran perfect. Put my old injectors back in and, yep runs like crap.
I am sure the basic rules apply. Replace old gas, add a f/w filter in addition to the E-85 additives, and finally use that boat often.
