Brian_in_Waterford
- Aug 9, 2009
- 21
I'm attempting to bring my (inherited) '85 Bayliner back to life. I went to the boat shop yesterday and purchased a new 500 amp battery. The dude behind the counter at the shop told me that the old 730 amp battery that came with the boat was way too big for my (inherited) 50 hp Force motor and it's 6 amp alternator. He also told me that the voltage regulator was most likely damaged due to excessive load from the old too-large battery.
So I have several questions:
1) Is the guy at the boat shop correct?
2) Attached is a photo of what the thoughtful PO left behind under the seat. I assume the thick cables are from the engine and attach to the outer posts. I assume the yellow and red wires with the ring are the ground and attach to the negative inner post. Is this correct?
3) Now it gets messy. The red wire with electrical tape ends in a broken fuse holder and a second red wire has been snipped in two. In the glove box I found 1/2 of a damaged fuse holder and a black wire with a second fuse holder. I assume both these wires (with fuses) are supposed to attach to the positive inner post. I assume I need to replace the fuses and holders, splice them into the existing red wires and seal with heat shrink tubing. Correct?
4) Or, instead of replacing the fuses and holders, would I be farther ahead to install a fuse box under the console? The boat is equipped with a fish finder and bilge pump and I may want the flexibility to add additional accessories in the future.
5) I assume the plastic box is for the battery. Is it supposed to be fastened down in any way or does the battery just rattle around free?
6) Finally, I've seen a couple of posts that mention the Universal voltage regulator. Would it be a good idea to replace my (potentially damaged) regular with the Universal? How would I test my regulator to see if it's properly working?
Thanks much! Sorry about the long post.
