  #1
Old September 7th, 2009, 01:48 PM
Whaler Bob Whaler Bob is offline
Default 1968 40HP Evinrude -changing spark plug wires
Hello, I'm looking for advice on changing the spark plug wires on '68 40HP Evinrude. I've got the service manual, and it describes changing the coils, but not the wires. I have removed the flywheel. What's not clear (to me) is how the wires attach to the coils and whether I need to remove the armature plate or not. The wires are routed underneath this plate, the manual says to remove it when changing coils. I just want to replace the wires. Any words of wisdom.
I have searched the messages here and saw some good advice on what type of wires to use when I do change them.
Thanks,
Whaler Bob
  #2
Old September 7th, 2009, 09:05 PM
lindy46 lindy46 is offline
Default Re: 1968 40HP Evinrude -changing spark plug wires
You can change the wires without removing the plate, but it's a lot easier if you take the plate off. You have to remove the coils to get to the wire connectors anyway, and two of the coil bolts hold the plate in place. there are only two more bolts which hold the plate down. Once the plate is removed, it's easy to work on the wires from underneath, and there are several wire hold down bolts which can be easily removed. Pull the old wires off and install the new wires through the proper places in the plate, leaving a little slack at the coil end. Then screw the new wire ends into the coils, and pull on the wires slightly (to take up the slack) while fitting the coils back into place. Once the coils/wires are installed, replace the hold down brackets and put the plate back on. I usually leave the wires long and cut them to the proper length once everything is back in place.
  #3
Old September 8th, 2009, 01:57 AM
kbait's Avatar
kbait kbait is offline
Yep, Pull the plate. It's really easy once you do it. I work on these all the time, and I learned long ago that whenever I service one, I pull the plate, replace the plug wires (using the old caps and connectors), inspect the coils for cracks, remove points and file ALL pit's out, then reassemble, gap the points, properly torque flywheel, and check spark with my tester. They always test fine after that, and I've never removed the flywheel again because I missed something. Good luck!
  #4
Old September 8th, 2009, 10:12 PM
Thanks for the good advice. I'll read up on disassembly and give it a try. Can you tell me how the wires are attached to the coils? Are they screwed in, or does the little cap just pull out of the coil along with the wire?
Thanks again,
WB
  #5
Old September 8th, 2009, 11:27 PM
tx1961whaler tx1961whaler is offline
The spark plug wires just push into the coils. Make sure to use the wires with actual stranded wire in them, not the carbon type auto wires.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 150 Spark Plug Wires brewhaha Johnson & Evinrude Outboards 3 May 2nd, 2009 10:00 AM
Replacing spark plug wires on 1953 evinrude 15 horse penning7 Johnson & Evinrude Outboards 2 April 23rd, 2009 11:59 PM
core spark plug wires for boats vs regular auto spark plug wires coolguy147 Non-Repair Outboard Discussions 5 October 20th, 2008 10:10 AM
1981/83? Evinrude 115 Spark Plug Wires 2shallow2sail Johnson & Evinrude Outboards 2 July 28th, 2008 02:01 PM
evinrude spark plug wires laguna freak Johnson & Evinrude Outboards 0 August 3rd, 2007 09:42 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
