Water in bottom cylinder 1990 force 50hp
Billie Jean
Hello boat world! I am new to i boats but have been reading several different posts for the last week. I have a 1990 Force 50hp that has water in the bottom cylinder. Prior to changing the head gasket i has 150psi on top and 120 psi on the bottom.I changed the head gasket and have 150 psi on both cylinders.
Did a test run and it seems like it was running worse and more water is in the cylinder.
I am going to replace the exhaust gasket however i did not see any obvious damage when i removed the cover. Also if that gasket was damaged would water be in both cylinders?
Any help or input would be greatly appreciated......
Blade_Link
Re: Water in bottom cylinder 1990 force 50hp
i dont think there would be water in both but id be looking for a crack in the block, at no time should water even get near the cylinder use a heavy oil mix to keep that motor from seizing
john from md
You may have damaged the head gasket during installation. You did use a torque wrench to tighten the bolts didn't you?
John
Billie Jean
I have a repair manual and a good mechanical background. However, I do not know much about outboard boat engines.
Could the impeller water tube o-ring up top have something to do with it?
Thanks
john from md
If the upper seal is missing or damaged, usually it would cause a leak and you would get an overheat alarm. I can't see it having anything to do with the water getting into the cylinders.
John
