  #1
Old August 24th, 2009, 11:24 AM
pieps57 pieps57 is offline
Default 18 hp evinrude over heating
I have a 1973 18 hp evinrude that is over heating...
Now is it for sure the water pump?
Can you tell if a water pump is bad when you pull it?
Im not exactly sure how the cooling system works on boat motors...
There is some water coming out of the hole its suppused to on the back of the lower unit ......
Any help is greatly appreciated..
Thanks
  #2
Old August 24th, 2009, 11:35 AM
bktheking's Avatar
bktheking bktheking is online now
Ensign
Default Re: 18 hp evinrude over heating
No not for sure, yes usually you can tell , the vanes on the pump are broken/distorted, could be the pump housing or plate it rides on, could be a blockage in the cooling system as well. Most motors have a thermostat, i'd pull that out and check to see if it's functioning in a pot of boiling water and a thermometer. Mist coming ou the back is a good thing but it all depends on how much mist, a good pumping pump should puke water out that hole, not spray bottle type mist.
  #3
Old August 24th, 2009, 12:06 PM
Daviet Daviet is offline
Master Chief Petty Officer
How long have you owned this motor? If the pump has not been changed in the last 2 or 3 years, it is time to do it anyway. Be sure to check stat if your motor has one. What year is your motor?
  #4
Old August 24th, 2009, 12:41 PM
bktheking's Avatar
Ensign
He said it's a 1973.
  #5
Old August 24th, 2009, 01:09 PM
So where is the thermostat on it?
and what do i do to check if i need to "unclog" the coolant system?
  #6
Old August 24th, 2009, 01:22 PM
Rick. Rick. is offline
For thermostat location check this link. Actually you can learn lots about your motor just viewing the parts breakdown but an OMC service manual for your specific model and year is a valuable asset.
http://shop2.evinrude.com/ext/index....5dbcb952e42681
If the system is plugged up there could be several steps required including pulling the head, but do the impeller first. That will normally be all you need do. I would pull the impeller and check the condition of the pump housing as if it is scored and/or badly worn it should be replaced at the same time. Best of luck. Rick.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
15hp evinrude over heating native son Johnson & Evinrude Outboards 6 December 11th, 2008 01:27 PM
evinrude v4 110 over heating skidaddy65 Johnson & Evinrude Outboards 6 September 9th, 2004 07:57 PM
60 evinrude over heating alarm alexcalvin Johnson & Evinrude Outboards 2 August 3rd, 2003 07:27 PM
1983, V4 90 HP evinrude over heating jgrover92064 Johnson & Evinrude Outboards 1 July 8th, 2002 05:58 PM
1983, V4 90 hp Evinrude Over heating jgrover92064 Johnson & Evinrude Outboards 1 July 8th, 2002 03:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
