I have a 89 Force 85hp that starts great when I blast a little starting fluid (which I now know is BAD). However, when I'm out in the water and sit for a bit then try and start, I have to give it full throttle in neutral to get it to start, and in worse case scenario blast it with a lil more starting fluid then it fires up. If I drop it down to idle it dies. If I want to go I have to drop it down from full throttle neutral to drive real quick so that way she takes off. Any idea what could be the problem here? I replaced the fuel bulb last year and it stays hard now. Any ideas would be very helpful, thanks!
