need timing specs for a 1999 4.3 gl volvo plan on running 87 oc fuel. i have the shunt
R randallscott Recruit Joined Jul 13, 2009 Messages 3 Jul 21, 2009 #1 need timing specs for a 1999 4.3 gl volvo plan on running 87 oc fuel. i have the shunt
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Jul 21, 2009 #2 Re: 4.3 gl base timing specs What is the actual FULL model number or SN for the engine. I would bet you have a 99 boat, but engine and boat years are usually different.
R randallscott Recruit Joined Jul 13, 2009 Messages 3 Jul 21, 2009 #3 Re: 4.3 gl base timing specs engine ser no. 4110181588 type 4.3 gl pwtr prod. no. 3868941
R randallscott Recruit Joined Jul 13, 2009 Messages 3 Jul 21, 2009 #4 Re: 4.3 gl base timing specs haul no. gla16572l899
Don S Honorary Moderator Emeritus Joined Aug 31, 2004 Messages 62,321 Jul 21, 2009 #5 Re: 4.3 gl base timing specs Well, you covered all your bases. The WT in the model number is what I was looking for. 8? BTDC Here is a post that will explain the proper method of setting the timing on your engine. http://forums.iboats.com/showthread.php?t=271407 Here are some manuals you might like to read. http://www.4shared.com/dir/14518373/c484ddd4/WTsharing.html
