I took off the neg and pos cable from the motor's control cable and now forgot where the two cable's hook back to the motor. Can someone help.
Ground or negative [black cable] bolts to eng. block.Positive [red cable] goes to starter input stud.
make sure you hook em up correctly... if not you will fry your rectifier
