I've read a couple posts about replacing the intake screens, but they were for smaller engines. I'm assuming the procedure is the same for mine, but I wanted to check.
1. Remove Impeller Housing (Replacing)
2. Break up the existing screen box and remove
3. Insert new screen box and snap into place
It looks like it should slip in, but its a tight squeeze with the drive shaft and bearing housing right there.
Do I need to remove any of the bearing housing, or can I just drop it in?
Thanks
Thanks
