Hi everyone: My first post.
Can i install a 1987 evinrude 90 hp flywheel (E90TLCUR) on a 1989 evinrude 90 hp engine (E90TLCEM)? Will there be any problems with any balancing differences?
I've tried that and the parts #'s are different. The 1989 part # is (0583339), and the 1987's part # is (0582628).
Some one local said that it should work, and that didn't sound to re-insuring to me. Do you know of any other way to cross reference the two part #'s.
OK: thanks you tx1961whaler.
I installed the 87 flywheel today and the starter from the 87 model.
It seemed to be OK but the starter was dragging like it was in a bind and may need to be spaced out. I only ran it for a minute or so. I'm going to let it set instill I'm sure.
