how about a 1997 90 hp Evinrude 60 degree looper?
thanks
bob
Bob, you are probably best starting your own thread in the evinrude forum. I know all 2 cycle "rudes" with 70 hp or larger are set to 6p. So I will guess your is not set to 6p. You can always set the tach to every setting and then see which is close to what your idle rpm is supposed to be... not the best approach but possible.
Good luck!
