I just recently bought this motor. The guy fired it up for me with the muffs on and it started on the 3rd pull. I loaded on the back of my truck, strapped down and drove about 10 miles home. I put is on the stand and put in fresh plugs and new foot oil.
Now I am not getting any fire to the plugs. I have read through several post on troubleshooting the problem and still not luck. I have tested at all the recommended test points and some things don't add up. My Red lead from stator to switch box read correct on resistance(550 ohm) and volts(20V). My blue lead reads a little high on resistance(6400 Ohms) but only getting ~20V. At the coil I am only seeing about 2 volts. Between the brown and white leads I am seeing 660ohms and I see the specs call for more like 150ohms.
I have alread disconnected the kill switch lead and have it taped off during all test. I can't believe something could have went this wrong with just a short ride home.
I really don't want to take this thing to the shop but running out of ideas. Any help appreciated.
Shane
Shane
