johnnybyankee
- Apr 20, 2009
- 9
hello all i am working on a 1986/87 mercruiser 3.0 inboard that has a gremlin somewhere i have replaced the points with a pertronix electronic unit as well as the coil no spark from the coil to the distributor so i then took pertronix back out bought new points and condensor set as well as cap and rotor and still no spark from the coil which is brand new could i have a bad ground maybe or fuseible link bad maybe everything works as it should i.e gauges tilt trim shift interruptor etc i am lost can someone please help i tried even bypassing the harness and putting 12 volt straight ot coil and still nothing no spark any ideas fellas ? thanks john
