Stator Resistance Test
Status
Not open for further replies.
maciejl
I have merc 50 hp 2001 2 stroke.
I performed the stator resistance test/It should be between 0.16-0.19 the ohmeter was crazy running and did not show stable reading. In the ignition stator resistance test should be between 660-710 and was 920. What it means Should get new stator?
My engine looses power drop rpm and then goes back again to perform normally. From time to time drops power. Stator could be the reason, should I get the new stator?
CharlieB
Re: Stator Resistance Test
Hope you didn't damage your ohm's meter.
Ohms test CANNOT be done on a running motor.
The leads from the stator should be disconnected from the ignition module.
Ideally a stator should be tested with a DVA Meter while running.
maciejl
Please dont get me wrong test was performed with disconnected battery. I was just training to explain what is wrong with my motor.
So do you think with all those reading I need new stator?
verado7
first -you need to listen more carefully - to what other posters are telling you.
you cannot test a stator's resistance (ohms) with th eengine running .
you cannot test a stators output with a standard volt meter you need the more expensive DVA meter .
disconnecting the battery wont help you test a stator - you need to disconnect the stator leads from the switchbox.
86RajunCajun
you can however test the ohms resistance in teh stator windings to see if they are shorted by performing the ohms tests you have already done.
If the ohms readings you got were not what the manual considers passing results, then you should replace the stator.
I tested my stator with ohms readings and the readings were not within the passing range, so i replaced it and it was the problem. the tests were accurate to diagnose a faulty stator.
GL
RC
maciejl
First, did I ever said that I tested the stator when engine was running? NO
Did I ever mentioned that I did not use DVA $180 meter? NO
Maybe you should read more carefully what questions people are posting.
Anyway, is there any possibility that dva measuring ohm device while checking ignition resistance test could not give stable reading?
Laddies
Banned
Why would you ask when you have all the answers to start with? With a glib tongue to go with them.
maciejl
I am sorry that I hurt your feelings. I was not the one who started articulating based on the false assumptions.
Karl_Childers
DVA is for measuring voltage not OHMs. If it is a detachable DVA adapter, remove it for checking OHMs.
DVA-direct voltage adapter
Good luck
Rob
LemonHead17
Re: Stator Resistance Check. 1990 Force 50. Engine wouldn't start. No spark at spark plugs. Removed stator from engine. Resistance check made on workbench. According to Seloc Force Outboards 1984-99 Repair Manual, The resistance is supposed to be 500-1000 ohms. Trouble is the manual didn't specify how to make this check. I didn't know if the test was to be made between two wires or one wire and metal ground of the stator. There were six wires present on the stator. I tried every combination of checks between two wires and checked between each wire and metal ground of the stator. I kept getting an infinite amount of resistance on all the checks made.
Bought a used stator on ebay for $125. After watching a few YouTube videos, I found out there were two resistance checks to make. One between each set of the three paired wires. I still didn't know which color of wires were considered a pair. The ebay stator gave the following readings: with one of the ohmmeter probes touching the metal terminal of the brown wire with a blue stripe (marked #1) and the other probe touching the metal terminal of the brown wire with a yellow stripe (marked #2), the reading was 750 ohms. Then with one of the ohmmeter probes touching the metal terminal of the brown wire with a blue stripe and a black stripe (marked #3) and the other probe touching the metal terminal of the brown wire with a yellow stripe and a black stripe (marked #4), the reading was 750 ohms.
On the ebay stator the remaining two wires were both yellow and unmarked. The resistance between these two was 1 ohm. I rechecked the resistance between the two yellow wires of the bad stator, it also read 1 ohm. I must have missed that on my first test of the bad stator when I went through all the possible combinations.
Tested each individual wire of the six with stator metal ground and each read infinite resistance.
Installed ebay stator on engine and it fired up and ran. Hope this helps somebody.
Status
