Hi! I have a 1974 ranger 2 bass boat with a 1974 50h.p. evinrude mod# 50743m. 1st.boat! Runs great on boot in yard. Took to river started great ,warm up leaver works correct, idle good,throttle forward plains out then dies. Now for the trouble.Has elect. fuel pump 35gal. per. hr. with pressure reg. matching unite,pr.reg. from .05psi. to 6 psi. Had to set at 5psi. to run on boot. If I take it off it will flood.Will not pressure up and even.flood unless turned off when not running.Are floats stuck? Any help would be greatly welcome. Happy fishing!! THANKS ALL.
