Suzuki--can't get gas to carbs--HELP !
esox1
I have a 1989 Suzuki DT 25. Ran fine 2 years ago when last used--went to start it and I can't get any gas to the carbs---
1) I checked the hose and tank connections--I can get pressure and gas to the engine
2) checked the fuel filter and I get gas pushed through the filter lines
3) checked the fuel pump and it pumps when the engine is cranked and I get gas to the carb
NOW I can't get the gas into the float bowl of the carb--Just won't pass through the plastic line mount into the carb?? ANY IDEAS on what might be up. Motor runs fine on gas sprayed into the carbs--Just starves out because no fuel is reaching the carb??? I need Ideas on where to go from here? Thanks JIM
SMD4
Re: Suzuki--can't get gas to carbs--HELP !
check the throttle lever and connector which are plastic pieces in the engine compartment, check if broken. They should move when you push the throttle forward. They were off for me once and caused me trouble.
