Ok, I just got this boat. Its a 1989 70hp Evinrude motor. It ran well before I messed with it, but was a little moody idling. I proceeded to pull the carbs (3 of them) and clean them. I just did a spray clean. They looked clean and I just sprayed out the bottom jet and all orfices I could get to...some of the fuel lines seemed a bit loose and all they had on them were zip ties.
Now it seems like its running weird when I open it up...it surges, then slows down, the goes to WOT for a sec, then boggs.
I am almost sure its the loose fuel lines, because some were too loose in my opinion. I am going to changeout the lines and get clamps and I am pretty sure thats the problem.
Could I have messed up the carb somewhere though in case the fuel lines arent the problem?
When there is 3 carbs to a motor, do they have to be adjusted at all? Or is everything fixed?
thanks
Matt
thanks
Matt
