sunbird 18
- May 19, 2008
- 78
I just got my o2 sensor diagnostic sensor harness in today. I am trying to troubleshoot a high rpm running condition. When I first run the boat away from the dock, I get about 5300 rpm. After it gets good and hot after about 20-30 minutes, I only get about 5000rpm and I can feel the engine surging a tiny bit and I can hear the engine rpms varying quickly(breaking up) Hooked up the o2 sensor harness after thoroughly cleaning the sensor and It averages about 0.6V It quickly varies from 0.54 to about 0.67V. First off the book says .3-.6 MILLI-Volts indicate a good sensor. I am reading .5-.7Volts, noy milli-volts. When I cover the #1 throttle plate hole with my finger, the reading goes from 0.65ish to about 0.74ish after about 4 seconds. with my finger still in place, it eventually drops back down to 0.67V. When I remove my finger from the hole in the throttle plate, it goes back up to 0.74ishV and then back down to 0.62ishV. It is supposed to spike high when covered and then spike low when uncovered. It never goes low. I let the engine warm up for over 10 minutes, no codes, cleaned o2 sensor, link and sync'd.
What is your interpretation of these numbers?
TOmorrow is going to be fuel rail pressure testing.
Any ideas?
Thanks!
Any ideas?
Thanks!
