dsacalaitman
Thread starter- Joined
- May 6, 2009
- 1
I recently replaced my trim motor. I have a single ram trim. After changing the motor it will only trim down. I then heard a clicking sound from the relay with the blue wire. Relay was replaced and still the same out come. Then I swapped the connection from blue to green and when i actuated the switch down the trim then lifted i then swapped back the connections as they should be and i hit the down button it went down. what could it be the switch ? also the swith on my bow does the same as by my throttle.
