After replacing the powerhead to adapter gasket and all fuel, oil and recirculation hoses, motor idled better than last year even w/o a link and sinc. But had a leak- removed top carb and fixed a spit end on one of the new recirculation hoses. Reinstalled carb but no longer idles nicely. Never done a link and sink before and have a few questions.
I?ll have to skip the max spark advance and cam follower pickup timing procedures, since after two years of searching I still haven?t found the test wheel (386246).
Both the OMC and Seloc manuals are nearly identical on how to do this. I did the throttle valve sinc- loosened both the throttle cam follower screw and the lower carb adjusting screw, let the throttle shafts snap closed, and tightened the lower carb adjusting screw while pressing down on the adjusting link tab. Neither manual said to tighten the cam follower screw before proceeding, so that?s my first question. Next I moved the cam follower to verify that both throttle valves begin to move at same time. Wouldn?t the cam follower screw need to be tightened before doing this?
Next the cam follower pickup adjustment- with an amplifier on the top carb shaft, both manuals say to slowly rotate the throttle cam until the amplifier begins to move, and at that point the mark on the cam should align with the center of the follower. But again, should the follower screw have been tightened prior to doing this? If it should be tightened first, should the cam follower be rotated slightly one way or the other before tightening the screw?
Last question- should the throttle cable be removed prior to this procedure, or should I just unlatch the throttle level at the remote control box so I can move the throttle at the engine? I appreciate the advice.
