longstand
- May 2, 2009
- 293
I have a OMC V6 3.8 Engine
Engine:
OMC
Model# 382STMRCNG
this engine is from my old 1983 Regal Ambassador 247 XL
History of the boat.
I purchase the boat 1 year ago. it run fine. but ones i put the boat into the water it overheated both engine
Someone told me it may be the water pump. so i remove the water pump thats on the engine and it was fine. The water pump was rusted and where the water inlet that goest to the Engine
Well I remove the Exhaust manifold and found out that is rusted also, i clean it up and it's all good now.
While i remove the Exhaust manifold The EXHAUST RISER PART #910158 was so rusted i hit it with a hammer it made a hole ( boat RISER On One ENgine )
So i purchase two OMC EXHAUST RISER PART #910158.
Well iam going to put all this part this coming Saturday. and i need some advice of what may cost this Overheating problem.
So far I think its the water pump that is on the Sterndrive is causing this problem.
My Idea is-- if it is the water pump that is on the sterndrive is damage. i will connect a Hose from Flush To a High Power Water pump that will get the water from the sea to the Engine
I look at the diagram it seems like what ever water that goes from the water pump from the sterndrive go to the same area.
My Fist Big Boat. Have some question.
Do the SternDrive has to be cooled ? Or only the Engine needs to be Cooled.
Iam not really sure what is sterndrive but is it where the propeller is located. the big bulky Metal Hanging out on the *** of the boat is a sterndrive?
What kinda Lubrication Should I use to Maintain this Boat Beside the Engine and Powerstering. I mean the Gear Oil and the Trim .. LOL iam pulling all this from my SOLOC Boat Manual. It said i should use Gear OIL to maintain it. but did not mension what kinda oil..
What OIL's Should i buy?
What is the Easy way to find out if the water pump located next to the propeller is working?
Engine:
OMC
Model# 382STMRCNG
