92 40 hp evinrude no spark
mazak14
1992 40 evinrude has no spark either cylinder. One day it ran fine next day nothing. Fuse in motor area is good & I checked all the connections, making sure they are tight. Where should I look first power pack, coils, keyswitch? I bought a manual & have someone that can possibily use a voltmeter. Motor is on a pontoon boat at my cabin won't be going there for 2 weeks. Thanks Dan.
EN2
Re: 92 40 hp evinrude no spark
Check kill switch first. Or unplug cable under cover, jump solenoid from hot cable to nearest small terminal, crank, while checking for spark.
