  #1
Old May 17th, 2009, 05:38 PM
guyren's Avatar
guyren guyren is offline
Default 90 evinrude water leak
Hi there. I wanted to post this issue for some feed back. The picture name rude 2 shows the area (in the red box) where it appears the water leak in coming from. Picture rude 1 is for reference so you know where you're looking. This is a 1987, 90 horse evinrude
Now, I am not sure how to fix this or even where the water is coming from exactly as it all pools there and trickles down the right hand side (looking at pic 2). Is this as simple as umbolting the power head from the ouboard and changing the gasket?
I used the motor like this all last season, put on about 10 hrs or so.
  #2
Old May 17th, 2009, 10:46 PM
emdsapmgr emdsapmgr is offline
Default Re: 90 evinrude water leak
You have marked the bottom of the outer exhaust cover as leaking. If water is coming from this cover, it is a simple fix. You will not need to pull the powerhead, but will need two (they are the same gasket) exhaust cover gaskets. If it is leaking below this cover, it could be leaking in the seal between the powerhead and the midsection adapter-called the base gasket. In this case, you will need to pull the powerhead to replace the gasket.
  #3
Old May 18th, 2009, 07:00 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
also the 2 humps below the box are the thermostats.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old May 18th, 2009, 09:48 AM
guyren's Avatar
so I removed to exhaust covers today. The gasket (outer one) seemed to be cracked at the bottom right at a water jacket passage. It's Victoria day today in Canada so it's a stat holiday and everything's closed. I will order some new gaskets tomorrow. When fitting the new gaskets, is it recommended to put any type of adhesive, marine adhesive? See new picture of exhaust area.
  #5
Old May 19th, 2009, 09:56 AM
guyren's Avatar
What type of sealant should I be using on the gasket mating surfaces for the exhaust covers, if any?
I've had some folks recommend that black gasket making compound made by permatex. Is that OK?
  #6
Old May 19th, 2009, 03:43 PM
guyren's Avatar
Last quetion, does anyone know the torque for the exhaust cover bolts?
  #7
Old May 20th, 2009, 06:48 AM
You will need simple gasket sealer, like a permatex type. It's the dark brown type applied with the cap that has the brush built in. The bolts are small, so they only need 5-7 lbs of torque. I'd retorque them after the engine has gone through it's first heat/cooling cycle.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2000 90 HP Fuel/OIL Ratio.. Water Leak? dain Johnson & Evinrude Outboards 2 April 1st, 2006 11:10 PM
2000 Johnson 90 hp water leak redskin1 Johnson & Evinrude Outboards 4 January 1st, 2006 10:58 AM
lower unit gear oil leak! 90 Evinrude mstevens61 Johnson & Evinrude Outboards 7 December 16th, 2005 04:48 PM
90 hp evinrude-year and cooling leak tom thompson Johnson & Evinrude Outboards 2 September 22nd, 2003 07:13 AM
1987 90 inline 6 Cyl. Mariner water leak jbrandes Mercury & Mariner Outboards 1 April 16th, 2001 05:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
