Hi,
Someone gave me a hitch for my truck, it just didnt have the hardware kit.
I made a trip to the hardware store and picked up some 2" Grade 8 Bolts,
grade 8 or 5 cant remember, flang lock nuts,
some round washers,
and some 2"x2" Simpson Strong Tie Bearing plates, with 1/2 Inch hole that goes on the frame.
I have it setup to wear it goes bolt, bearing plate, frame, flang nut.
Is this gonna be strong enough hardware for towing? and do i need to put the flat washers on with the flange nut or with the top bolt and bearing plate
I took a photo for reference, sorry its kinda crappy quality i took it with my cell phone. the bearing plats over hang my truck frame by 1/2" is this alright. The ones that come in the kit are 2" x 1.5" i believe. I do plan on torqing it to 75 ft lbs when im done.
What do you think, think i'll be ok with this setup? The spot is mounted in is the first availabe hole, theres one on the other side as well then the rest need to be drilled out. Hitch is held in place with C-Clamps
Thanks first time doing a hitch install on my own rig, i mainly just do wiring for people.
some round washers,
