  #1
Old April 25th, 2009, 02:58 AM
HONKER1 HONKER1 is offline
Send a message via AIM to HONKER1
Default '01 Mercury 115hp 2-stroke Water Pump
Didn't want to hack another members thread, but would like to clarify something in my own mind.
I had the water pump rebuilt last year by a trusted outboard motor mechanic and was getting 19 lbs water pressure. This year after sitting for 3 months, I started the motor in a barrel and I wasn't getting water out of the P-tube and became worried and shut the motor down. Restarted several times, but with no water out of the P-tube and motor showing signs of getting hot I would shut her down again.
I removed the rubber hose that connects to the water jacket, and there is nothing blocking it. Even ran the motor without the tube, to see if water would exit the water jacket. I just find it hard to believe that the water pump is bad, with the little use it had in one year. I would only run it for 15 minutes per trip.
Now for the question.... When the water pump picks the water out of the barrel, would there be NO water out of the P-hole if the thermostat is closed. I suspect the thermostat is not working or I am to paranoid to let it run long enough to let it open. Could I remove the thermostat and put the cover back on and see if water comes out the P-hole. This would at least tell me if the water pump is working or not. Thanks for any help you can give me.
  #2
Old April 25th, 2009, 09:56 AM
CharlieB CharlieB is offline
Default Re: '01 Mercury 115hp 2-stroke Water Pump
Not sure on your model without walking out back to look at mine, but yes, the in-line 4's should 'P'
The V-6's, many will not 'P' until the T-stat opens.
Did you use an OEM impeller or aftermarket?
Aftermarket are NOT of the same material as OEM and do not withstand exposure to the air as well as OEM.
I've seen 'new' aftermarket that aged on the shelf, that I would not install.
  #3
Old April 26th, 2009, 01:37 AM
I am pretty sure he used a OEM. I saw him walk over to the display rack and get a Mercury impeller off of it. Will be taking the motor to him on Monday to have it checked out. I realize strange things can happen with water pumps. I am just a little hesitant about dropping the lower unit. Some members have been having problems with the shifting afterwards.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercury 30HP 2 stroke - Water Pump Smileysaab Mercury & Mariner Outboards 3 March 10th, 2009 01:21 PM
Mercury 115hp 4-stroke water in oil Gus49 Mercury & Mariner Outboards 2 February 23rd, 2009 05:25 AM
'01 Johnson 25HP water pump mikesim Johnson & Evinrude Outboards 1 May 15th, 2008 07:48 AM
Fuel Pump Rebuild Kit '01 Merc. 4 stroke 75 hp Nit640 Mercury & Mariner Outboards 5 September 28th, 2004 08:21 PM
Water pump, 1998 115hp Mercury 2 cycle braunri Mercury & Mariner Outboards 0 May 26th, 2003 08:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
