Fuel pump
dieselcat
The part # for the fuel pump for my 1995 88 spl is 433387.I searched the web for a pump and all of em i find that replaces this part # says it's for a 25-55hp motor up to 1989,doesn't make since.can someone help me with this?
If the pump is only made to provide enough fuel for a 55hp motor,thern how is it gonna fuel a 88hp motor?
F_R
Honorary Supreme Mariner
Re: Fuel pump
The amount of fuel supplied has nothing to do with it. What does matter is that it fits, and the hose nipples are the right diameter, and pointed in the right direction. The final determining factor is how it gets the pulses to operate it. Some have a hole in the back for that and some have a third nipple for a pulse hose.
dieselcat
Re: Fuel pump
Does it matter which direction the nipple for the inlet on the pump is pointed when the pump is installed on motor?mine is pointed directly at my starter and the outlet[going from pump to carbs]is facing straight down.
