Outdrive nut lock?
Johnshan1
Alright this is interesting-
Went to pull my drive off to replace the bellows and service the u joint, and one of the bolts has been replaced with a locking nut similar to the type you find on alloy wheels of cars.
Where can I find a key for this? Guess my boat came from a bad neighborhood in Mass to need this kind of thing.
Re: Outdrive nut lock?
Ayuh,.... Ask the previous Owner....
Or,...
Cut it Off...
Don S
http://www.iboats.com/Stern_Drive_Locks/dm/*******.309551600--**********.704133943--view_id.39201
Johnshan1
Don thats pretty much it, a little different.
I just cut the outer cover off and used a big screwdriver and hammer to get it off.
Problem solved, guess I should have tried that before I ran in and posted.
Thanks.
HT32BSX115
Chances are you got a lock from McGard like the one above.
Click on the above link and it'll take you to their site. You can get a replacement "key" from them if the original owner registered it with them and after you jump thru a few hoops.
I would get 2.
I keep one in my tool box and the other one is up under my dash held in place with a plastic zip-tie. Same with my prop lock!!
Cheers,
Rick
