protecliners
Thread starter- Joined
- Mar 11, 2009
- 2
Hey all,
I am new to this forum but have been reading for awhile for good info. I currently have a 1986 wellcraft 192 american that has turned into a pretty good project. My current dilemma is I was looking over the motor mounts because I am getting ready to install my freshly rebuilt mercruiser 470 in it and found the front motor mount to be rotted out. So decided to cut out the piece and replace the wood and fiberglass. While cutting out the piece I didn't pay attention to the cut depth on my saw and cut right through the hull with about a 4 inch long 1/8 inch wide slice. Now I know I messed up big time and I have worked with fiberglass before so I think I can repair this. Nearest I can tell, on a marine application, I basically need to grind down the area about about 3 or 4 inches around it (do expose the surrounding fiberglass) and basically fiberglass both sides and build up the fiberglass to make it about the same strength. If anyone has advice for me or any tips, I would greatly appreciate it. Thanks in advance.
