Re: 2000 Johnson 150HP Carburated
Got a chance to work on the engine tonight and had a set back in figuring out the problem.
I started the engine and I kept squeezing the gas line primer bulb, and the engine still started to sputter and stalled out. I did this a number of times with the same results.
I then mix oil and gas in a spray bottle and sprayed in the cylinders as soon as I started the engine and it made no difference.
Based on this I started to think it wasn't a fuel problem, but I kept thinking about the fuel pump that wouldn't pump when I checked it on Sunday. I decided to check the fuel pump again and it seems to be pumping fine. I don't think I made a mistake on Sunday when I checked it, but why would it be pumping now. The only thing I can think is that I had the hose off from cylinder #6 crankcase when I check it on Sunday. I don't think I was that careless, but I can't explain it any other way.
Regardless, with the fuel pump working the engine still ran the same way, starts, idles for a few seconds and then starts to sputter and then stalls, usually with a final backfire.
I then checked the fuel pump pressure by putting a guage in line right where the fuel line leaves the fuel module assembly. The pressure was between 3 and 4 PSI. I also ran a hose from the fuel module output, into a bottle and each time I tried to start the engine, it started to fill the bottle, until it stalled out. I did notice after the engine was sputtering, during the stalling phase, I noticed some small air bubbles int the gas line which I had run into the container. I think this was from the rough engine running.
I also removed the fuel plug on each carb, one at a time and flushed the bowls out by pumping the fuel line bulb.
I will check the compression on each cylinder next. Do you have any further advise? Thanks again for all your help!
