I just got a 1978 Evinrude 55hp. Seems that one of the studs that the starter bolt thread into has been snapped off. By stud I mean the cast part of the crankcase that the starter bolts would thread into. Can this metal be welded and if so what kind of welding shop should I look for? I dont know what kind of metal it is but its cast. If it cant be welded are there any ideas on a fix? This is the top bolt for the starter and without *** being fixed the starter wont engage the flywheel correctly. Can this be pull started somehow?
I just bought the motor and the seller had it jury rigged to last long enough to make the sale. Starter started grinding on the flywheel 2 days after I got it home. I should have taken a better look.
