How do I top up power trim/tilt fluid
Peter105
I have what I think is a 1976 70hp Evinrude (Model 70673D - Serial A312733?) & don't know where/how to put in fluid to fill up power trim to replenish after leaving manual release screw loose & loosing a lot of fluid.
I have never had to put fluid in & don't think I even have the correct spot (screw on starboard side of cylinder about an inch & a half from the bottom? When I start to unscew this more fluid just comes out.
Can someone please provide a diagram/description of where the correct spot to fill it is & if the spot I described is correct how do you get the fluid to stay in?? Can someone please help/advise.
