  #1
Old March 15th, 2009, 10:15 PM
Crowiv Crowiv is offline
Default 2003 yamaha 250 saltwater series II alarm
I have a 2002 intrepid with twin 2003 250 saltwater series II and was out this weekend dolphin fishing and after about 3 boys of trolling, I got an alarm on my port motor. My digital guage was showing the three oil level bars flashing. Thinking I was low on oil I put a gallon in and restarted the engine and the alarm was still on. Shut it off again an checked the oil tank which was half full. If I just turned on the key the alarm was on and would not go off. I limped back in on one motor and when in calmer water raised the motor but no obstructions. When I got back to the house, I turned the key on and there was no alarm. Any idea what kind of problem I have? Is is possible I have an oil sensor which was not functioning and raising the motor fixed? Thanks for any help.
  #2
Old March 15th, 2009, 10:59 PM
cousinabe's Avatar
cousinabe cousinabe is offline
Default Re: 2003 yamaha 250 saltwater series II alarm
oil transfer alarm.
the engine oil tank is low, there is enough oil in the remote tank that automatic oil transfer should have occured.
check the filter at the bottom of the remote tank outlet for restrictions.
its possible to have a slow transfer due to a restriction that will allow the tank to refill at low speeds but the engine will consume it faster than the transfer can occur at high speeds thus triggering an occasional high speed alarm that will quit shortly after its brought back to idle.
normally if it actually overheated it will take 10-15 min to cool that chunk of aluminum lower than about 155 degrees to shut off the overheat audible.
The engine oil tank got too low, the remote oil tank had oil in it and the transfer did not happen fast enough.
here's a similar post with testing procedures.
http://forums.iboats.com/showthread.php?t=288110
Thumbs up on the Intrepid!
  #3
Old March 16th, 2009, 12:17 AM
Thanks for the quick reply! And the possible quick and cheap solution! Something else dawned on me while reading your reply: lately the port engine has been using less oil that the starbord, could that be due to a flow restriction which was getting worse finally resulting in my experience this weekend? I'll postthe results of my investigation.
  #4
Old March 16th, 2009, 10:18 AM
rodbolt rodbolt is offline
what cousinabe says.
3 bars flashing means the system malfunctioned and is trying to alert the operator.
but ya gotta quit with the sensor thing.
your oiling system has NO sensors.
it has a 3 position switch in the engine tank for transfer pump on,pump off and alarm condition on.
the remote tank has a switch that is closed if oil level is sufficient for transfer and open when remote tank level is low.
low remote and the center bar or yellow lamp is illuminated and automatic transfer is inhibited and there is enough oil for about 2 manual transfers.
NEVER remove the engine oil tank switch/screen assy to fill the engine tank.
if the switch/screen assy is removed make sure all the oil has been manually drained Via the water trap and the screen seal is retrieved and a new seal installed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha, 1996 Saltwater Series v-x 250 gigigeo Yamaha & Suzuki Outboards 1 October 12th, 2008 01:38 PM
2001 150 Yamaha Saltwater Series II OS66 Btuvi Yamaha & Suzuki Outboards 0 August 9th, 2008 12:20 AM
2003 250 Saltwater Series Oil Issue chefchilders1 Mercury & Mariner Outboards 0 June 23rd, 2008 03:03 PM
1999 Saltwater series II Yamaha Problem jidigill Yamaha & Suzuki Outboards 7 May 20th, 2008 09:57 AM
2001 Yamaha 250 Saltwater Series NedFinney Yamaha & Suzuki Outboards 5 December 23rd, 2004 08:50 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
