Engine ? 300 Hp Mercruiser Mag MPI 350 Cubic Inch
Electronic Ignition / Fuel Injected
Serial Number ? 0L684218
Year ? 2001 (I believe)
Hours ? 150 Since totally rebuilt in January 2007
Prior to having the engine removed to replace the oil pan because it was rusted and leaking oil the boat performed as follows;
RPM at WOT ? 4300 to 4600 RPM
32 MPH
Fuel Pressure ? Perfect as required by Mercruiser I believe 43 PSI
Upon removing the engine from the boat I decided it would be advantages to go ahead and replace the spark plugs, wires, starter, rotor cap, rotor and gimbal bearing on the Alpha One outdrive.
Upon taking possession of the boat back from the mechanic the boat performed as follows;
RPM at WOT ? 3500
15 MPH
Fuel Pressure ? Does not reach Mercruiser requirement I believe it?s at 25 PSI
The fuel pressure at this point does not register what the Mercruiser manual indicates which is around 43 PSI and the engine is starved for fuel. At this point the engine was removed from the boat again and a new Mercruiser fuel pump and fuel regulator was installed and the fuel PSI still does not register what is indicated in the Mercruiser manual. It is registering as follows; idle 15PSI and at load 25PSI.
I decided to take the engine to a Mercruiser mechanic is Miami and he has yet to figure out what the problem could be. Last week the injectors were inspected to make sure that one or more of them were not staying open thus not allowing the fuel pressure to build up. I paid $203.00 for testing and cleaning the injectors only to be told that the injectors are fine and it?s not what is causing the problem.
Everyone is totally baffled and don?t know what else to do to resolve this issue.
Again, before the engine was removed the boat was running perfect.
Hope you can help!
Thanks,
Max Barnes ? (305) 788-8572 Cellular
32 MPH
RPM at WOT ? 3500
15 MPH
Hope you can help!
Thanks,
