Troutrider
- Jan 4, 2009
- 4
I just picked up a 12 HP Gale Buccaneer in a trade. I'm fixing up an old 14 ft. Alumacraft to take the boy fishing and trying to decide if the Gale is worth tearing into. The spark plug wires are cut off at the ends. The motor turns over with a pull and everything seems to be there. Is there anything in particular I should check before spending time and money on starting a resto? I just don't want to spend a bunch of money and end up with a bomb. I've restored a bunch of motorcycles but haven't done an outboard. Should I check the compression or do a leakdown test? Are the bottom ends pretty bulletproof? The wife has put up with plenty of burned $$$$ on bikes so I want to try to be sure of what I have before throwing money in the bottomless pit. Thanks.
Trout
Trout
