ellasdad04
- Jun 11, 2006
- 6
15 ft fiberglass tri hull 1986 Mariner 40HP 2 Cylinder w/ Yamaha<br /><br />i have hit a few rocks but recently while driving the tilt let go and the motor dropped while doing 30 mph. Just the prop looks as though were damaged, changed it and went out as planned, when i start to get moving 30-40 % power the transom seemed to be being pushed in to under the water and wasnt picking up speed. there also is a large hump of water behind the boat. i adjusted tilt tight to boat (normallly 4 slots out),<br />ran better but motor sounded LOUD and began vibrating and of course wouldnt plane properly. shut off and trolled back. used a hangar jig to check prop shaft. small warp dont have shims but i used to work CNC shop i would say .020+.. with prop on you cant see any difference when spun? could you tell what i need to do parts anything will help. I also have recently noticed a small amount of oil from #2 spark plug cylinder stained on engine. more than normal oil in cylinder too. # 1 has dry burnt oil on plug thats it.<br />I was given the boat by my father in law who passed recently and he had kept boat good but also didnt use much. it was missing most of skeg when i recieved it also. Always starts before most the new boats on the launch. idles a little high but dosent die. Always grinded when getting in to reverse though.<br /> the boat does 28.6MPH ... the motor " dropped" on the pave ment while going over railroad tracks and the prop smashed pretty hard. missing 40% of one of the prop fins. Luckily the lower unit is a shy short of touching the ground while being towed. sorry about the missed info
