1980s mercruiser, 140 HP manual?
Status
Not open for further replies.
sickwilly
Ok, I have no ssn, etc. I was at my buddies house the other day and this year he picked up his first IO -- he has always been an outboard guy. He had not winterized it, and yes we have had some freezing nights.
Here is what I know: Its an early 1980 mercruiser with 140 hp, and a 4 cylinder engine. I can get more information off of it Thanksgiving.
I was hoping to find an online manual to do a little reading on it.
Upon learning he had not winterized it, I jumped in it and found two brass drain cocks, one on the side of the block and one on the bottom of the exhaust manifold (same side of the block). I got both them open and drained--I had to probe with a wire into the exhaust manifold. I saw no others.
I was thinking I would change out his outdrive oil when I go over there Thanksgiving before it freezes again, if I can figure out what kind it takes.
If there are any manuals on line, please point me to them. If I need more info, I will get it later this week.
Trent
Re: 1980s mercruiser, 140 HP manual?
You also need to drain the exhaust elbow. Three drains on that puppy.
sickwilly
Thanks! I will look for an exhaust elbow when I go over there on Thanksgiving. The boat owner is also from Southern Alabama, but they call it, LA -- lower Alabama!
North Beach
Thanks for the link! Just finished the download:D
Scottcw
Trying to download the manual as well. Keep getting "critical error" message?
Fun Times
Hi there Scottcw welcome to iboats.:)
Since we're not even sure what manual you're trying to download or find, it would be best to start a new topic of your own vs bringing up someone else's archived topic of many years ago. If you're not sure how to start a new topic of your own than the following link below should help you out with that.
Thanks iboats Mod team.
How to ask a question / Create New Topic
Status
