AguaSki
- Jul 4, 2005
- 545
A couple years back I installed a digital OMC tachometer. Yesterday at the lake I noticed some weird numbers on the display while cruising. At low to mid range rpm the tach display is normal, but when I accelerate past 30 mph (about 4,500 rpm) the tachometer starts displaying random numbers. The display refreshes about every second and when it does I will see something like this: 1284, 5296, 3851, 5417, 2149 etc. Of course those are not the actual numbers I am seeing on the display, but you can tell the numbers are completely random and don't make any sense. If I pull back on the throttle to get under 30 mph (somewhere under 4,500 rpm) I notice the display starts to show me reasonable RPM's that seem accurate again. If I try to accelerate the random RPM display returns. It feels like 30 mph and 4,500 RPM is the point where the problem starts on acceleration and where the problem ends on deceleration. The whole time my tach is displaying these random RPM numbers, my motor is running flawlessly. I could not sense a change in the performance of the motor. Any ideas on what is going on here? Do I have a bad tach, bad stator, bad battery, or bad rectifier? Please share your thoughts.
The motor is a 1978 Johnson 140 hp.
