  #1
Old December 20th, 2008, 12:56 PM
graybird graybird is offline
Default aluminum boat repair
I have a 12ft Sears jon boat, that I bought used in 1976. The boat has served me well over the years in small waters using trolling motor.The boat was sitting on ground in 2004 when a tornado blew a tree down across on side on right front, crumpling that side of boat for about 12in. Is there any way to straighten that portion that was crumpled down and then of course repair the aluminum that was torn when side crumpled. Thanks for any advise. Graybird
  #2
Old December 20th, 2008, 01:06 PM
DJ DJ is offline
Default Re: aluminum boat repair
Hammer it out with a large rubber mallet (weighted). Back up the areas that you are hammering with a weight.
You'll get some cracks as aluminum doesn't "bend" very well.
Have the cracks and splits professionally welded. It won't be pretty but it will be functional.
  #3
Old December 20th, 2008, 01:10 PM
Bard1's Avatar
Bard1 Bard1 is offline
You could try to beat it out and rivet a patch over your hole with sealant. might be too thin to weld.
__________________
WE LOVE FUN STUFF!!!!!
  #4
Old December 20th, 2008, 03:48 PM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Ayuh,...
Realistically,....
Scrap it....
There's No Way in 'ell it's worth the Effort to rebuild it....
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #5
Old December 20th, 2008, 05:13 PM
Shizzy's Avatar
Shizzy Shizzy is offline
Ensign
depends on what you are looking to accomplish and what this thing looks like. If its not horrible I can see pounding it back close and having a few spots welded. I had great Success on a bent up Canoe with some wood blocks, some large C clamps and a big rubber mallet.
I clamped on a block longer then the bent area, and put the large C clamps to the middle of the bent area nice and tight then beat on the area with the mallet. after a few attempts and repositioning I had it close enough.
However, if this thing has been flattened I would probably pull the plug.
__________________
'68 Alumacraft FD, '65 Johnson 6HP "The Sea Monkey"
  #6
Old December 20th, 2008, 06:28 PM
ylop ylop is offline
really we need some photos of the boat before any advice can be given the last time a boat was brought in with this type of damage for repair it was written off as the only way to repair it was to replace the hole side and transom.
smaller dings can be repaired as described Shizzy.
__________________
BUGGER TIN I HAVE PLASTIC
  #7
Old December 20th, 2008, 08:29 PM
kaferhaus kaferhaus is offline
In my area boats that size in good shape are selling for $150 or less (no motor or trailer).
If you can't fix it yourself in a few hours then it needs to be sold for the scrap.
  #8
Old December 20th, 2008, 09:38 PM
mphy98's Avatar
mphy98 mphy98 is online now
use a dead blow mallet, strong piece of wood on the other side, have someone that can weld aluminum weld up cracks and possibly a support bar by the bend. should ony cost a couple of bucks to get it welded. always hate to see a boat go to waste if it can be saved
__________________
1979 thunder craft viking ss18
  #9
Old December 21st, 2008, 12:14 AM
sschefer sschefer is offline
The correct way to repair aluminum is to heat it to between 300-400 degrees and watch what it does. Aluminim will try to go back to its prior shape when heated and that's exactly what you want it to do. You can coax it with a body hammer and backer dolly but never try to make it right all in one shot or your sure to create cracks that will continue to creap for ever. Often studs are spot welded to strategic points and a puller used to gently pull the metal while heating it.
The trick is the heat. You never want to exceed 400 degrees or you will soften the metal and it will go wacky on you, (you can reharden it but it's difficult to get it right again). If you cool it too quickly you will anneal it and it will crack. Bosch makes a LED heat gun that works perfect for this job. I use one and have removed every dent and ding from two of my boats, (well all but the 12" gash, that's a different process).
It will take time so set your patience meter to high and go slow and easy. You will be amazed at how straight you'll get it. By the way, this is the way that is taught in the automotive repair schools.
As a side note - If the metal is extruded (stretched) then you will have to grind a cut into the length of the extrusion in order to get it to lay flat again. You cannot de-extrude the metal without special equipment (rollers). You also cannot beat an extrusion back to shape because it doesn't work that way.
Hope that helps and good luck.
Steve
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum Boat repair - Rivets? twostep Boat Topics and Questions (not engine topics) 29 March 2nd, 2009 08:17 PM
Keel repair on a aluminum boat ShafferNY Boat Topics and Questions (not engine topics) 7 February 28th, 2008 06:25 PM
Aluminum boat repair RyBisp Boat Restoration and Building 6 June 15th, 2006 01:58 PM
Repair on aluminum boat. fastwater Boat Restoration and Building 1 April 9th, 2006 06:41 PM
aluminum boat hole repair harleydyna Boat Topics and Questions (not engine topics) 7 April 24th, 2002 08:12 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
