ncreappraiser
- Oct 2, 2008
- 17
I hate that this has to be my first post but I am in a jam.
I have a 92 Evinrude 90HP that had a 2 leaking bowl gaskets on the carbs but was running fine other than an cutting off issue at idle. I removed and cleaned the carbs, replaced gaskets, seal and needle and seat. With out changing any adjustments I reinstalled the carbs and now the boat sounds loaded when first cranked then is idles between 1,000 and 1,500. I have attemted to make a few adjustments and even removed the thottle cable thinking that is was binding. I can get it down to 1,000 but that is by adjusting the timing advance and it starts running rough. I do not have a manual and cannot get my hands on one for a few weeks (money issues). I'm trying to sell the boat (again money issues) and the fuel leak had been a point of contention. Amy help will be greatly appreciated.
****edit model number is TE90TLEND****
