  #1
Old November 1st, 2008, 12:05 AM
Starcraftguy1's Avatar
Starcraftguy1 Starcraftguy1 is offline
Default 1995 Mercury 40 hp fuel Answer
Ok, I had a couple 0f post here on this motor.I have fixed everything possible by a human.And to tell you the truth,there was nothing really wrong.trying to make a 2009 out of a 1995.There was bad gas,cleaned and emptied tank,replaced fuel filter 2 times,changed plugs,ran a tank of carb cleaner through tank,1/2 tank and 1 pint to be exact,I had installed an inline fuel filter ahead of motor,in fuel line,replaced that as starved engine of gas,3 miles an hour slower,on the way to the lake tomarrow morning,I have purchased a manuel,new carb gaskets,new fuel pump rebuilding parts,installed new Mercury fuel line with bowl to get rid of inline filter that I installed,top speed was 27 miles per hour at 5,000 rpm's.Bass Tracker Pro Deep Vee 17,I think that I got it,if not,carb rebuilds,fuel pump rebuild next weekend.Trying to fill the freezer with a lot of 17" crappies.Before the rebuilds.What do you guys think.Good or Bad.
  #2
Old November 3rd, 2008, 04:30 PM
hamit59 hamit59 is offline
Send a message via MSN to hamit59
Question Re: 1995 Mercury 40 hp fuel Answer
Hi
What is the problem with the motor? Is it starving for fuel or do you just want to get more top end out of the motor? I know for some with the tracker come with a 13" pitch prop. That works great for the boats if it don't have a lot of load on it. I have the tx185 pro. When I loaded my gear into it, Top end was less that the 27 mph you are seeing now I changed the prop to 11" pitch and picked up my top in to 32mph @ 5675wot. I have a 50 4 stroke on it and I'm happy now my hole shot is good and the top end is fair as well.
My last question is what is your wot rpm? By the book it should be around 5750 rpm. If the 5000 is the wot then you are running your wot a little low.
__________________
Hamit
BT1 USN ret
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1995 Mercury 40 hp Stalls In Drive or Reverse Starcraftguy1 Mercury & Mariner Outboards 5 March 12th, 2009 07:49 PM
1995 40 HP Mercury Trim/Tilt issue kwood0527 Mercury & Mariner Outboards 11 February 22nd, 2009 08:45 AM
1995 mercury 40 HP tilt and trim? chodie Mercury & Mariner Outboards 0 July 1st, 2008 06:41 PM
1995 Mercury 30/40 HP Troubleshoot aselle Mercury & Mariner Outboards 3 April 27th, 2007 12:28 PM
1995 40 hp Bucko51 Force & Chrysler Outboards 2 July 27th, 2004 10:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
