I want to make sure I put my flywheel back on properly. I removed it because I wanted to see the condition of the wires connected to the stator (Original Problem: http://forums.iboats.com/showthread.php?t=272210).
Model: Mercury 402 (2cyl, EL - Electric Start, Long-Shaft)
Serial Number: 7102322
Year: 1977
First off, I didn't remove it properly (no flywheel puller - rookie ignorance). Basically, I removed the bolts in the flywheel to get it off. I didn't smash it with a hammer or anything.
1. I removed the main nut/washer connected to the crankshaft.
2. I tried to pull up using my hands. Wasn't going anywhere.
3. Then I removed the bolts in the center of the flywheel. I started on the outside (I only removed two and was working on the third when i realized it was loose). I just lifted the flywheel off. I discovered that the stator also had sealed wire connections and no terminals, so I simply put the flywheel back on.
I bought a torque wrench and tightened the nut to 75 ft lbs (as per manual). I can't find the torque specs for the other bolts I removed on the flywheel. Any suggestions for torque on these ones?
The reason I'm concerned, is that there seems to be vertical "play" with the flywheel. The nut/washer is tight to the flywheel (ie. there isn't a gap on top or anything). It's just that the whole things moves up/down a little bit. Video below shows what I mean.
Flywheel Up/Down movement
http://www.youtube.com/watch?v=vpZHOAZeS7g
Motor Running
http://www.youtube.com/watch?v=OOhDu5F7Tow
Thanks,
-Cambo
Year: 1977
Motor Running
Thanks,
-Cambo
