cheburashka
Thread starter- Joined
- May 28, 2005
- 715
This problem has been plaguing since half-way through the summer. '74 Mercruiser 140, Pertronix Ignitor ignition, Pertronix 3.0 ohm flamethrower coil, 1-year old plug wires, carb rebuilt last year. Good squirt from accelerator pump, solid idle. Idle adjust screws and idle speed set correctly. Clean flame arrestor. Compression 130/128/125/132. Good premium gas.
Toward the first half of the summer everything was great. Good hole shot, got to within 200 RPM of WOT and all was smooth. Now, I get it out on the lake and hit the throttle and it stumbles and runs poorly until it hits fairly high RPM, at which point everything suddenly smooths out. If I keep it above 2500 RPM, it runs very smoothly with lots of power. If I let it drop below 2500, it stumbles and continues to bog.
I've tried it getting on the accelerator slow, getting on it fast, and just about any other way I could think of. About the only way that really made any difference was if I revved it up above 2500 in neutral, dropped the RPM down to idle, then got on the throttle immediately.
I'm trying to teach my kid to water ski, and with no hole shot he's going to be miserable.
Tomorrow I'm installing my backup carb which soaked in cleaner for three days and has been meticulously rebuilt. I've been swapping back and forth between the two and either they both have the same thing wrong with them, or it's something other than the carb.
Any suggestions?
Any suggestions?
