bibi_00612
Thread starter- Joined
- Aug 21, 2008
- 2
Hello, I own a 1986 175 hp Evinrude since 1997. I'm sure that the charging unit hasnt wochange rked .I had the voltage/regulator changed. Still not charing the battery .i test the stator and itis ok i read 12vac at the out of the stator . Idisconnect the rectifier/regulator and use an ohmmeter to measure the resistance between the two wires going from the rectifier to the stator. This should read just a few ohms. There should not be any connection (i.e. infinite ohms) between either of these wires and the engine earth.
still no charing the battery
